Brief Description: Control Cable Firewall Fittings
Another lathe project, I made my own firwall fittings.
Glued to pieces of bar stock together. Turned into a rod Threaded one end, tapered the other. Split the taper end so it would clamp Turned an AN fitting nut with a matching internal taper.
