Continueation of the oil door mod. I finished up the oil door with machined bushings (yay lathe), sping, and pivots. An alternative to the bolts would be a solid shaft from one side to the other, but with a step machined in so that the nuts can be torqued. The joint could also be floating with cotter pins and washers to set the play. To much end play will let the door fret the cowl.
