I received the new hose I needed to finish the fuel line routing. I installed the correct fitting into the red cube and painted the mounting btacket. I made the bracket white so and fuel leaks (blue 100LL) would be ver obvious. I am still waiting on one fitting for the fuel pressure sender line then I will be done with this assembly.
