I did some more work on the exhaust system. I changed out the clamps on the tailpipe and adjusted the support rods. It looks pretty good now.
I also worked on the engine baffles some more. I have most of the baffles fabbed up, not it is just a matter of fitting them to the lower and then upper cowl. Once the metal is fitted to the cowl, I will added the baffle seals.
