A little more work on the FWF today. I fitted the fuel feed lines and temporarily mounted the carb. I also installed the recepticles for the CHT probes. The threads were pretty gunked up so I chased them with a tap and everything went right in. I also installed the pressure sensors onto the block that will bolt to the firewall.
