More work on the cowl today. I removed the prop and spinner then finished drilling the cowl to the hinges that attach it to the firewall. I then fitted and drilled the hinge that connects the two halves. I didn't take any specific pictures, but I also notched the front of the cowl for the hinge pin and then made up the pins to fit. I also made the pins that attach the upper cowl to the firewall.
