Before I install the engine mount and engine I went ahead and fitted the hinge sections that will attach the cowl to the fuselage. The engine mount will get in the way a bit if I do it later. I left the large pins that come with the hinge in place for the fitting to help with alignment. I will swap to the smaller pins once everything is in place. I left the ends of the hinge oversize and will trim them later.
