After I finished fitting the canopy frame I had Gina help me carry the canopy out to the shop and set it over the canopy frame / rollbar. From here I will start marking and trimming the canopy. Once I have a good rough-cut, I can make any more required tweaks to the frame before I final-trim the canopy. Since it is summer, it is a perfect time to do the canopy work. The canopy is more brittle and prone to craking when it is cold. The 100+ temperatures in the shop should help lower the risk of cracking while trimming.
