I got some good work done today on various items. I put the flap weldment back in place and fitted / drilled the center support. There wasn't sufficient edge distance on the F-605 flange for the bearing bolt, so I made a doubler the ties the baggage rib to the F-605 and provides a solid place for the bolts. I installed -3 nutplates for the bearing block bolts. I trimmed the floor panels around the block.
I then proceeded to re-install all the interior panels so I could fit-check everything, and it looks cool..haha
