More canopy work today. The canopy shape is getting pretty close so I am able to set the horizontal position of the rear canopy track. The the track position determined, I can now finish fitting the rib between F-606 and F-607 along with the gusset. I fitted the rib and put a couple tack rivets from the gusset to F-606 and to the rib. I also made the angle for the aft end of the rib and riveted it to F-607.
I also did some more bending on the canopy frame and have it nearly in shape, but I will likely spend a few more days messing with that frame before I can drill the aft rail to the fuselage.
I trimmed the skin back just a bit more and now everything can move without rubbing.
