After finishing up on the seating area I moved aft and started fitting the baggage side walls. I got a good start with all side panels fitted and most drilled. I then started making the bends at the bottom of the side panels to support the outer portion of the baggage floor. The forward half of the baggage walls get screwed in place and also acts as the cover for the flap actuator. The aft portion of the of the sidewalls get riveted in place.
Left side baggage walls fitted and pilot drilled.
Just a cool shot of the tailcone from inside the baggage area.
