Totay I received the Reddish Stall Warner I ordered from AS&S. This is a very well made item that is a welded assebcly that looks like it will hold up well.
The instaructions that came with it aren't the best, but I am pretty sure I got it right. I marked out the location on the LE and cut the oval hole for the tab and then drilled the mounting holes. I enlarged the rib tooling holes and installed grommets for the wiring. I ran 22awg since there will be very little current load on the circuit. I ran the wire up one of the ribs to the LE by using the zip-tie block blind-riveted to the rib.
