Brief Description: Right Aileron and Flap Fitting 2
Today I fitted the aileron hinges and aileron gap fairing to the wing. I also temporarily mounted the ailteron to the wing and began to fit the right flap. I used the same process on the right aileron as the left, and it looks like everything is in the right position.
To maintain the 1/4" gap between the aileron and flap, I taped two 1/8" thik bit of srap together and then taped them in the gap.
