I did my first pressure test on the right tank. Unfortunately, I found two very small leaks at the rear baffle. In an attempt to fix, I applied about 1psi of vaccume to the tank and put some thinned proseal at the leak hoping it would get sucked in. I doubt it will work, but it was worth a try. I will probably have to remove the access panel to fix one and add and access panel to the rear baffle to fix the other. Everything else is leak free.
