Brief Description: Left Wing Access Panel Modification 1
I would like to be able to visually inspect the bellcrank durring pre-flight and decided to add a window to the access panel. I marked out the "stayout" zones on the panel and layed out where the window would be. I cut the corners with my fly cutter and used shears and files to finish it. I then cut out a piece of lexan (.085) to fit.
