Drilled the second row (aft) of tank to spar flange attach points, plus the tank to leading edge attach points. Drilled some out to #19 and installed what few nutplates I have in the forward spar flange. Cut access panel hole on the end rib using the fly cutter. The fly cutter worked great. One thing with the fly cutter, it leaves a very sharp edge on the cut-out metal. Well, this I decided to keep the leftover pirce from the cut as scrap. Right before sutting down for the night I decided to deburr the edges so I wouldn't cut myself later. Like an idiot, I didn't put on my gloves. The jagged edge of the "rasor frisbee" caught on the deburr wheel and fired across the workshot, passing through my finger on the way. This one will take a few weeks to heal. The cut is worse than it looks, and actually quite deep.
