Today I removed the clamps on the fuel tank flange and cleaned everything up. Getting the pro-seal sqeeze out off is a load of fun. There can't be a lage bead on the rear baffle/skin joint since that will prevent the tank skin from setting flat on the spar flange. I also encapsulated the shop heads on the baffle.
