COLIN'S WEB SITE
Date:  9-27-2009
Number of Hours:  0.00
Brief Description:  Left Wing Bottom Outboard Skin 3
Finished drilling the skin to all but the overlap rib and the ailer bellcrank rib. Layed out the wing access panel on the skin. I scribed the corner radius with a compass and then used the fly cutter to cut a clean corner. I then trimmed the access hole out with the shears and cleaned up with the file, edge deburr tool and my 2" deburr wheel. Came out great!. The second picture is just after cutting the corners and the third is after cutting with the shears, but before finishing.
