I have the tail attached and have been working to rig the elevator. I am running into interference issues with the forward pushrod. The pushrod is breaking the plane of the seat pan at max elevator travel. I have confered with other builders quite a bit and many of the RV-6 builders with newer kits are having this issue. There is some variability in the positioning of the F633 bearings, so moving those is one possible solution. I don't have a good picture of the issue to add.
