Today I finished wiring up the audio panel and the audio connections to the comm. I also ran the ground and power wires for the radio stack. I spent a lot of time cleaning up the wire bundles. I cut off the small zip times and replaced them with the slightly lager final version. I also replaced a lot of temporary zip ties with harness lacing. I connected the remaining wires to the main and avionics buss. I also ran an extra set of wires for a future portable GPS unit. I terminated the wires in a connector along with Serial 2 TX & RX from the EFIS. Now I can just make a patch cable to adapt any GPS in the future.
All the is left of the wiring is to terminal a few more wires at the ground buss and the shield leads. I still have to terminate all the engine sensors FWF and connect the Flap actuator. I am very close to some whole-system functional testing.
