More wiring today. I finally have all the wires running behind the main spar routed. Most are connected with the exception of the trim and control stick wires. I started to tie the bundle and get things cleaned up a bit. I could have done a better job with the order of the wires, but overall it came out pretty good. There are a lot of wires in that bundle.
I also routed, secured, and terminated the coax for the COMM antenna. I will add one more tie-pad to the floor for additional support, but I like the routing as is. I kept the bends broad and left a little slack in case I have to make future adjustments. The clamps are -4 so they don't fit tight. I don't want to crush the insulator and mess up the impedence.
Next time out, I will add some labels to the terminal block. I left plenty of room for later expantion.
