More electrical work today. I put the breakers into the panel and then started working out a way to buss them together. I thought about running individual wires from a terminal block, but that makes for a lot of wire. The traditional method is to use buss bars. The usual aviation breakers have screw terminals for this purpose. Since I am using a commercial type breaker with quick-disconnect terminals I needed a different method. I ended up soldering female quick connect fittings to the buss bar and then convering the whole thing with shrink tube. Those connectors aren't going anywhere and the shrink tube adds another layer of safety preventing a short caused by FOD.
