I spent quite a bit of time working out an alternative routing for the fuel tank vent lines. This routing would run the vent line inboard along the spar and then forward through the tunnel and around the perimeter of the firewall down to the vent fittings. I fitted the lines, but in the end I decided to scrap the whole idea since I simply don't have enough room in the selector housing for more plumbing plus the electrical I still need to run.
