A while back I made one of the tank-to-selector fuel lines. I was happy with the work, but did not like how many bends were in the line. I decided to re-do the lines to reduce the number of bends and to avoid passing through the gear tower since that would be a pain later. I did some trial and error and came up with a solution I think will work well. I want to make sure the routing is secure, but I also need to make sure the line are protected from damage. I will route the lines this new way and support them with a cushion clamp attached to one leg of the gear tower.
