Today I fitted the door for my map box. I didn't like the Vans setup so I designed my own. I had the door cut when the panel was done so the dor and hinge are an exact match. I used a flush oil-door hinge so the door is very clean. I will use a push-close, push-open type magnetic latch to hold the door closed. It will be really nice when it is all done. I also fitted the control for cabin heat, and riveted the map box together.
