More work on the tunnel cover. I made the new top and then also made a fron cover for the fuel selector housing. I fitted and mounted the fuel selector. The RV-6 and RV-7 orient the selector differently. I wanted to use the RV-7 method (I think it is better), but the outlets on the selector would interfere with the spar bolts, so I went with the normal RV-6 method.
