Today I did some more work on the forward fuselage. I marked and drilled the rivet pattern into the ribs. I also made / fitted most of the littile bits of angle that tie everything together with the sub-panel. I removed the ribs and sub-panel and did some priming. I need to pick up a 1/8" pop-rivet dimpler so I can dimple the holes in the firewall and rivet the ribs in place.
While I have the ribs and sub-panel out, I removed the rollbar and did some prep work on the caopy deck. I countersunk the longeron on the left side and dimpled the deck and rail.
