I fiitted and trimmed the baggage bulkhead. I matched the contour of the F-606 bulkhead by using the inside edge of the bulkhead as a guide. I traced the inside of the F-606 bulkhead onto the back of the baggage wall and then scribed a line 2" outside of that line. I then used the cutoff wheel, bench sander, and files to finish off the curve. it cam out great. I drilled holes where screws will go to connect the two halves of the wall.
I then fabbed up and fitted the seat-belt cable guides. The cables will attach to brackets bolted to the main longeron (earlier entry) and pass through these nylon guides on their way forward.
