Brief Description: Right Side F-622, 623, 624 Fitting
I had put off fitting the F622, 623, and 624 to the right side until I finished out the left side, that way I could find the "better" way to do it. The right side went much smoother and I had everything fitted in short order.
Once fitted, I marked and trimmed the skin with a little bit of excess in case things moved.
I then marked and pre-drilled the F-623. I put the right skin back in place and back-drilled the skin. I then filed the skin to the final fit around 623.
