After buying a new regulator and water separator, I finished drilling the side skin.
I then moved on to the mid bottom skins. I fitted the left skin and marked the rib / bulkhead locations. I then laid the rivet pattern out and pre-drilled the skin. I put the skin back in place and started drilling before it got away. I didn't finish the drilling, but the skin is well on its way.
