With all the stringers in place I fitted and marked the aft bottom skin and then pre-drilled the skin. I placed the skin back on the fuselage and match-drilled it to the stringers and bulkheads.
I then fitted, marked, and pre-drilled the aft center bottom skin. After re-fitting the skin, I started match-drilling it to the fuselage.
