Today I Finished fitting the left F-6101 and F-602. I then disassembled the left forward fuselage members, deburred, primed and riveted them in place (where appropriate). I will have to cut the flange on F-602 off where it overlaps the F-6101 and put a spacer there instead, otherwise there is no way to rivet the skin there.
I also fitted the left F-620 arm rest between F-604 and F-605. I then started fitting the F-632 and F-623.
