Iron down glue areas and use iron to take out wrinkles in fabric. Glue down fabric around the edges. Mark and apply gule for the bottom fabric. Cut fabric for the bottom half of the wing and apply per the directions on section 8 of the rans manual, Trim extra fabric and clue down outside with a brush and wipe method, Iron the top and bottom side to bring out wrinkles. Next step will be to install the rib strips and then inspection holes and misc other parts then tapes. I am going to do the LH wing up to the point of the RH wind and to the tapes and finish work side by side.
