Began working on the RH fuel tank setup, Built up upper root skin, Clecoed top root skin on and found top filler hole center drilled top filler hole and removed the tank to install fittings, layout the filler cap bolt pattern, Installed both RH and LH tip wraps, Lay out and dimpled the leading edge skins LH and RH, Marked and sanded the spar the the epoxy LH and RH, Got a call from Rans they said to put hot water in the tank and it would come back into form I did that and it worked now the tanks are the same and I will be able to install them. Installed foam on the leading edge of ribs, Epoxy the LH leading edge wrap and clamp into place,
