Worked on finishing up vertical braces, Installed wing tip bow, Worked on both RH and LH ribs used fluting pilers to remove bow in the ribs from factory, Modify the FWD attach clip and rear clip per the figure, layout the attach clips, Cleco ribs and clips into place before riviting. Rivet the LH side and install the cross braces, Worked on RH side riveted the clips to the ribs and modified the rib for the bellcrank,
