Finished up wing close outs and installed the wings per the manual, set wing washout per the manual, installed the wing tips and wired all lights to panel, ran aileron cables and rigged ailerons, put fuel in plane to check for leaks None Found, Completed fuel flow test with scale figure to be 49.8 GPH with pump on. Installed the fuel tank vents.
