Finished up the fuel system by puttinga 90 off the engine fuel pump. Finish installed the exhaust and mufflers, Installed the hose for cabin heat, Installed the baffel seal around the top of the metal, installed the spinner plate and the propeller base. Installed transponder antenna in belly, tied up misc wires in cockpit, worked on some engine settings in the G3X and other misc small things on my list before it goes to the hangar.
