I riveted the FL-706A angle on to the spar per plans using the squeezer with longeron yoke. I assembled the skeleton and cleco'd to the bottom skin.
I used the squeezer to set the rivets at the aft end of the internal ribs,
Cleco'd on the top skin and removed the spar. I used the gun and tungsten bucking bar to get down inside the flap and begin setting the rivets on the bottom of the flap where the top and bottom skins overlap. It was a tight fit, but was able to get good rivets. I set every other rivet working from the center out to each side.
