Stephens Web Site
Date:  2-4-2018
Manual Reference:  Section 7
Brief Description:  Fabricate FL 706 A
Fabricated the FL-706A from angle stock. Cut the part out on the band saw, filed edges and finished with belt sander and scotchbrite wheel. Edge finished the FL-706B. Match drilled the FL-706 A to the FL-706B. Marked the bend line per plans and bent the FL-706B six degrees to match the end rib using the vice and a large rubber mallet.
FL 706 A and B
FL 706 A and B
FL 706B bent 6 degrees
