Brief Description: Drill Left Aileron Seal and Flap Bracket
I cleco'd the aileron gap seal and the flap brace to the spar and then cleco'd on the bottom wing skin. Put a cleco in every other hole and drilled the spar with #30 and skins with #40 drills. Moved all the clecos and repeated the process.
