Stephens Web Site
Date:  10-22-2017
Number of Hours:  1.00
Manual Reference:  Section 7
Brief Description:  Rivet Left Wing Outboard Aileron Bracket
I riveted on the outboard aileron bracket. Used the gun and bucking bar for all the round-head rivets. Alternated between the rivets on the end rib and the spar, did a couple on each, then switched. Used the squeezer for the flush rivet at the bottom of the bracket.
Began edge finishing the flap brace and aileron gap seal with files and emory paper.
First rivets set
First rivets set
Almost done
Almost done
Squeezing last rivet
