Used the string and plumb bob method to set up the left wing skeleton as level and square with no twist and clamped it in place on the wing stand. Installed the leading edge section with 100% clecos. Used the squeezer to set the leading edge skin to spar rivets. Started in the center on the top of the wing and installed half the rivets, working from center out toward tip and root, alternating sides. Did the same thing on the bottom of the wing.
Cleco'd the aileron brackets to prepare for riveting.
