Brief Description: Continue to Rivet Right Wing Top Skin
I was able to use the squeezer to set the rivets along the rear spar. Started in the center and alternated every other rivet toward the root and tip. Installed half of the rivets then went back and filled in the rest. Drilled and removed the bad rivets from the outboard skin.
