Brief Description: Dimple and Prime Right Bottom Skins
Used the C-frame to finish dimpling the right wing outboard bottom skin. Removed the blue plastic and washed the skin with Dawn dish soap and water. Set aside to air dry. Taped off around the inspection plate holes so I could prime the mounting area without getting too much primer on the rest of the outside. Shot the skin with NAPA 7220 self-etching primer. Turned skin over and primed all mating surfaces where the skin meets the ribs and spars. Hung the skin on the spar inside out to dry. Did the same procedure to the outboard skin.
