Brief Description: Deburr and Edge Finish Right Wing Bottom Skin
Removed the right wing bottom outboard skin from the spar and deburred all the holes on the inside of the skin. Edge finished the skin using files, emory paper and scotchbrite. Used the vixen flie, flat file, emory paper and scotchbrite to taper the skin for the scarf joint. Began scuffing to prepare for primer.
