Brief Description: Begin Assembly of Left Leading Edge
I assembled the leading edge section on the bench, using a cleco from inside to hold the ribs in place then rolling the skin on and clecoing from the outside. Put a cleco in every hole as I worked from leading edge back. I left off the inboard rib with the join plate W-423 to facilitate access to the stall warning installation.
I used the squeezer to install the nutplates on the W-423 and the doubler for the stall warn access hatch. Then used the squeezer to rivet on the doubler.
Finished the day edge finishing the parts for the stall warning assembly.
