Brief Description: Continue Riveting Skin to Baffle Left Tank
Turned tank around and removed all the clecos from the skin to baffle line on the bottom of the tank, wiped area with MEK and re-inserted every other cleco. Mixed10 grams of sealant and began setting skin to baffle rivets, working from center outboard. Used wet rivet technique on all these rivets.
