Did a final wipedown with MEK and mixed 10 grams of sealant. Used wet riveting technique to rivet on the fuel pickup anti-rotation bracket and sealed the rivets and the nut on ell bracket. For the T-410s working solo, some rivets went well however I had one bad rivet on inboard end and four on the outboard end. I think the outboard rivets as called out in the plans may be a little too long, as I had similar problems setting good rivets here on the other tank as well.
