Stephens Web Site
Date:  10-23-2016
Number of Hours:  1.50
Manual Reference:  Section 7
Brief Description:  Rivet T-410s and Tank Bracket
Did a final wipedown with MEK and mixed 10 grams of sealant. Used wet riveting technique to rivet on the fuel pickup anti-rotation bracket and sealed the rivets and the nut on ell bracket. For the T-410s working solo, some rivets went well however I had one bad rivet on inboard end and four on the outboard end. I think the outboard rivets as called out in the plans may be a little too long, as I had similar problems setting good rivets here on the other tank as well.
Fuel pick-up riveted
Outboard rib
Outboard rib
Inboard with tank bracket
