Prepared to assemble the tank access plate with fuel pick up and fuel level sender. Marked the anti-rotation brackets and cut them apart on the band saw. Used the disc sander and scotchbrite wheel to smooth edges. Test assembled pick up on the access plate to see orientation and plan assembly sequence.
